Question about Ryobi Drills
Have a 18v ryobi battery that won't charge but when I put it into the charger it flashing green like normal but the battery is not charged. My question is do I have a bad battery or a bad charger?
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Is the green light supposed to flash while charging lithium batteries> just got the p113 charger but no instructions in the dang box
I have used alot of battery type drills and other action tools . Ryobi is on the lower end of the market as opposed to Milwaulkee and Dewalt . But my experience with battery operated tool charging equipment is that if the light is green and it's blinking , I would say it's charging . When the light goes off or stays on . I would say it's charged . Leaving the battery or batteries in the charging unit for 24 hours will not hurt the battery . My solution here is put it in the charger , and check it 12 hours later !
Electrician by Trade
Feb 20, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Mar 15, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
I have a new Ryobi 18V Drill which came in a package from Screfix with two batteries. I charged one of the batteries to start with and when the green light came on I used it and immediately charged the...
Take it back to the store and tell them it is no good, and get a new pair of batteries, take the charger too. I had the same thing, brand new batteries, gone in weeks, they replaced them, no problem.
Feb 21, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
18volt ryobi battery charger doesnt work
try pitting battery in charge and wiggle the battery a little to see if the green light comes on, sometimes the make contact and then loose it when you let go of the battery.if still same problem charger is probbly dead.
May 17, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Drills Logo
514 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
