Go to menu on Sony tv and turn off demo
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/bentley_420a7d90885c2203
Turn demo off in tv menu options
SOURCE: the picture has a pink and reddish hue
Any magician can make a trick look easy - but NOTHING replaces years of training and experience. That said, here's your answer:
If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It's important to write the values down before proceeding.
H Position: ________
V Position: ________
LCD ADJUST (NOT LCD DRIVE) (Arrow right)
GHOST (Arrow right)> LCD ADJUST =SHP: _______
(Press Select) LCD ADJUST GHOST=R: _______
(Press Select) LCD ADJUST GHOST=G: _______
(Press Select) LCD ADJUST GHOST=B: _______
(Press Select, then Exit)
V COM (Arrow right)> V COM-R: Set For Minimum Flicker
(Press Select) V COM-G: Set For Minimum Flicker
(Press Select) V COM-B: Set For Minimum Flicker
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice)
Scroll down to: “TA1383” then (Arrow right)
Scroll down to:
CONTM1: _______
CONTS1: _______ (Press exit)
After writing down these values, please continue:
SOURCE: I own a color TV 29
Hi! the problem you have describe denotes that you have a defective positive thermistor. the positive thermistor is the one responsible in turning on the degaussing coil to align the stray color on the picture tube during start-up.
SOURCE: 42 sony wega plama veritcal line
The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
Beware,the flatcables wich the resistors are located on are verry fragile!
SOURCE: My 42" Vizio lcd tv
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem with the solution provided....
SOURCE: att remote. how to program a sonya tv.
Click here to download the user manual to your remote control. It has all details.
