Distorted sound issue can be occurred due to loose connection, cable or problem with source. Check if Distorted sound issue is related to any audio/video files or any particular TV channel. If it is related to any audio/video files or channels then check on any different channels or play different audio/video file which have good quality audio. More info on: https://www.samsung.com/in/support/tv-audio-video/television-distorted-sound-issue/
In most of the case, the problem is the LED back lights strips, it was the most case we encountered.
To check it, un-plug the cable between the power supply & the main board, apply the AC power to it, if the back lights came on, replace the main board, if not, mostly the problem is the back lights LED strips.
the bit rate of audio is high thats why audio not support while playing video, use normal bit rate video or audio , u can convert your fav video and audio through your pc
