Question about Ryobi Drills
Ryobi hybrid blower, when trying to charge battery the green fault light comes on
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
Green light indicates fully charged. If not the case then unplug hold trigger in on position to drain all components then while holding the trigger in on position plug the charger in. If this fails it will need repair.
Posted on Feb 07, 2018
SOURCE:
rowdy45176
  • 2176 Answers
SOURCE: 18 volt ryobi battery charger...green & yellow lights come on wha
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
Posted on Dec 31, 2008
  • 3 Answers
SOURCE: charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Posted on Jan 15, 2009
  • 3 Answers
SOURCE: Battery charge problems Ryobi 18v
Solution is two fold. Will try the freeze and re charge approach today and do this a few times. The long term soluiton is to purchase two Lithium batteries and a duel chemical charger. Expensive solution but seems it will work.
Posted on Jan 16, 2009
  • 13 Answers
SOURCE: The Yellow and Green light both come on and stay
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Posted on Nov 24, 2009
radar001
  • 1051 Answers
SOURCE: My battery will not charge. ( Ryobi 18.0v)
Bothights on indicates a problem with the battery. You cam try cleanibg the battery terminal with a Q-tip moistened with alcohol. Allow it to dry completly before tryin to recharge. If that doesn't work the battery may be defective or broken. If it was dropped that could cause the damage.
Posted on Mar 10, 2010
Ryobi blower flashing green red when charging Won't charge
I have run RYOBI printing presses for the last 30 years and I bought a RYOBI rechargeable drill and rechargeable garden tool. I am disgusted by how cheap they were and how the batteries just gave up. I have heard about bumping a battery by running a good battery thru it. It was suppose recondition the battery, however I got two ruined battery for that.
Jan 04, 2018 | Ryobi Drills
I have a Ryobi 18 v 5 amp lithium battery which was attached to a blower but left out in the rain the blower motor still runs
This query does not appear to relate in any fashion to cameras or camera equipment. Would it be advantageous to repost it in a more appropriate forum ?
Dec 02, 2017 | Green Cameras
Green light on new Ryobi charger flashing when trying to charge battery it that normal
Yes, the green light flashes until the battery is fully charged on Ryobi chargers. This will change to a solid green light when the battery is fully charged until the charger goes to a power-saving mode. Not all of the Ryobi chargers have a power-saving mode. However, for those that do, the green led will dim over time and then brighten and dim slowly again in this mode.
My Ryobi charger, model P113, actually has a key for the LEDs on the unit on the left of the battery port. The manual for this charger is here: https://manuals.ttigroupna.com/system/files/5495/original/P113_192_trilingual.pdf?2011 . Ryobi has many of their manuals on their site. Look up your charger/tool here: https://www.ryobitools.com/power-tools/support/manuals , Home Depot's web site also has many of these manuals on the product site for the tools that they sell.
I hope this helps.
Mar 13, 2017 | Ryobi Drills
How do I call Ryobi regarding batteries?
You contact Ryobi for assistance. Have receipt handy.
Oct 13, 2015 | Ryobi Garden
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
RYOBI Charger problems
see you local ryobi dealer as this can be 2 different faults in the same unit.
Sep 20, 2009 | Ryobi Multi-Volt Battery Charger
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
18volt ryobi battery charger doesnt work
try pitting battery in charge and wiggle the battery a little to see if the green light comes on, sometimes the make contact and then loose it when you let go of the battery.if still same problem charger is probbly dead.
May 17, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Charger not charging
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi battery charger
Either the battery is hot from use or has been in the sun, let it cool down, then try again.
Nov 16, 2008 | Ryobi Multi-Volt Battery Charger
Drills Logo
41 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
