Question about American Standard Home
Bought 2 American Standard toilets model 4149A and the flush levers have been cutting us. Can we buy new handles
    Master:
  • 669 Answers
Yes you can replace the handles as they are available from American Standard, directly. Go to their web site, parts and service, and select you mod. toilet. Order from them. https://www.americanstandard us.com/bathroom/toilets-category
Posted on Feb 05, 2018
6ya staff
SOURCE:
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
Anonymous
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
co7196
Ned C Cook
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
mfraitag271
SOURCE: Square toilet seat made by American Standard Model TL 235.
This guy Allen in NY has lots of odd seats. Try him 914-963-6895
Posted on Nov 09, 2009
How to fix a toilet tank that won't flush unless you hold handle down for awhile.
Check to make sure the chain fromanagement the trip lever to the flapper does not have too much slack in it if there is shorten the chain so when the lever is down there is just a little slack in the chain. Hope this helps
Bob
May 29, 2013 | American Standard Home
I bought a house that has some older fixtures and all of the toliets (3) are the American Standard 13.2 / 3.5 GPF models. The one toilet in the main washroom flushes odd, in that when it flushes often a...
You probably have excessive buildup on the pipe walls that have restricted the flow to the point of needing that second flush - or somebody flushed a plastic bag there and now it is acting like a flapper. This will also be evidenced by occasional flooding at that commode. There's only 2 solutions as I se4e it.; scrape the pipe walls ( rooter with a scraping head ) or replace the pipe for the build up, or rooter out the pipe to try to extract that blasted bag.
Good luck!!
Nov 20, 2010 | American Standard Home
Bought low flow 1.6 litre American standard toilet problem I am having is it makes this clinging noise constantly and when taking off the tank lid you can see that is filling up a slight amount
Serval reasons: (1) noise from handle chain being metal-consider switching to lighter plastic type. (2) The rubber flap which lifts up when handle is pushed down and seals "when handle is let go" to allow water to fill in take maybe worn to the point of needing replacement-Go to any Lowe's/HomeDepot and they will walk you through replacement process of just removing old one and putting ends in place over hooks to install new one. Takes me 1 minute to do. (3) Adjust the water cut-off valve that supplies water to tank so it can feel up rapidly by just turning the value. If value is hard to turn try using some oil or WD-40 on it. Remember that one way opens to allow quicker fill up and better flush and other way just turns water to toilet off. If now of these things work then just give me a yell and I can advise further.
Oct 06, 2010 | American Standard Home
Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Apr 26, 2010 | American Standard Colony 2388.012.222...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Not flushing
take the lid off the tank and make sure that the chain is still conected from the flusher handle at the top of the tank to the plug at the bottom of the tank
Dec 09, 2009 | American Standard 2002.014 - Champion4...
Toto flush handle problem
did you try a new flapper? sometimes those are the reason they wont flush properly. check out the american standard cadet 3 it's half as much as a toto and works just as well
Jul 13, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Have to flush 2 or 3 times to empty toilet bowl
hope it helps
Dec 15, 2008 | American Standard Home
Home Logo
150 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
