Sewing Machines Logo
E
Ethleen Posted on Feb 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need manual for Bernina Software 7. Can you help me?
raysaw
Level 2:
Sergeant:
  • Expert 267 Answers
  • Posted on Feb 05, 2018
raysaw
Expert
Level 2:
Sergeant:
Answers
267
Questions
Helped
96654
Points
732
Which artlink is compatible window7, aurora 430 and embroidery unit.Artlink6 is working but doesn't allow me to write to machine.Editor lite v4 doesn't pick up dongle.Nothing wrong with USBports
This sounds more like a driver issue than a software problem. The ArtLink 6 software CD that came with the Aurora 430 had drivers for XP and Windows Vista. However, these drivers may have only been for the 32-bit OS. Windows 7 is the first version of the OS to have had a large number of 64-bit installations.
The latest drivers for the Aurora 430 is available here: https://berninaofamerica.zendesk.com/hc/en-us/articles/200183069-Aurora-Driver-Windows-Vista-7-and-8- . You will need to install two drivers; follow the directions on the site. Make sure that the USB cable is good and that you aren't using a USB hub.
If you have installed the drivers and the ArtLink 6 software still isn't working, ArtLink 7 is fully compatible with Windows 7 and the Aurora sewing machines. The only download site for this software that I've found is https://www.bernina.com/en-CA/Products-CA/BERNINA-products/Software-Designs/BERNINA-Embroidery-software/Advanced-Embroidery-Software/ArtLink-Seven . ArtLink 8 is also Windows 7 compatible. However, I haven't found any documentation on the supported sewing machines.
The driver issue also applies to the dongle. Try this site: https://www.bernina.com/he-IL/Support-IL/Software-he/Embroidery-Software/Dongle-Driver . However, since you have the Editor Lite v4, this dongle may not be supported under Windows 7. The dongle driver is not updated regularly. For some information about the software limitations, see https://www.bernina.com/he-IL/Support-IL/FAQ-he/Software-he/Can-I-update-my-BERNINA-embroidery-software-Editor .
I hope this helps.
(There is a patch for the v5 software to run properly under Windows 7. There isn't one for the Editor Lite v4 to the best of my knowledge.)
1helpful
Is it possible for the consumer to download firmware for bernina 730
Hello, Charlotte -
The Bernina 730 sewing machine was manufactured between 1963 and 1982, before Bernina came out with their first computerized sewing machine, the 1130 model.
Are you asking about the Bernina Artista 730 sewing machine, instead? If so, the answer is MAYBE.
I did find a brochure for the Bernina Artisa 730E model, which has a Microsoft Windows operating system built in and the myartista portal (online.) This is the link to the brochure (PDF document):
https://www.manualslib.com/manual/15724/Bernina-Artista-730e.html?page=2#manual
You may find this information on Bernina software products and which versions of Microsoft Windows software they are compatible with instructive:
https://www.bernina.com/en-US/Support-US/Software/Software-Compatibility/Bernina-Software-Compatibility
Best wishes.
Drivers for Bernina Software V5 on Windows 7
Bernina Support will generally help you with that. Otherwise, there are some Yahoo Bernina Groups with very helpful members who will have suggestions for you. You need a Yahoo email account. Search for Bernina groups and select the one(s) you would like to join, submit a request to be added as a member, and when approved, you will have access to all the files, photos, conversations, as well as being able to ask your own questions.
1helpful
2answers
Need Bernina Artista 200 manual ASAP
You can download a manual from the Bernina web site.
BERNINA Support Machine and Accessories Finders and Software Support...
Then go to "Search Support Info for Bernina Models"
BERNINA artista 200 Support BERNINA
2answers
2helpful
Artista embroidery program version 3.0 and Windows 7
For other versions and probably yours...
You'll need the following service packs to use BERNINA Embroidery Software V5 aand under Windows® 7 / Windows Vista™ operating system:
  • Service Pack 2 for BERNINA Embroidery Software V5 (V5.0W)
  • Aurora driver for 64-bit Windows® operating systems
  • Latest dongle driver
  • EConPC 3.1 & ADX 7.14
You'll find them at www.bernina.com\downloads
Hope this helped.
Rick
1helpful
Owners manual
Unfortunately this is a purchase site. The closest I could get would be for an Activa 220 230 240 . You can download the manual.
Check the picture on no. 7 and see if this isn't your machine.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Hope this helps. Luck!
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
