Question about La Crosse Measuring Tools & Sensors
How do i get a blue background instead of a grey one on the wireless la crosse model
  • 1 more comment
  • Brad Brown Feb 04, 2018
    Hi Mary ann, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Exact model number?
  • Mary ann
    Mary ann Feb 05, 2018
    Model WS 9037UN IT frequency 915 MHZ
  • Chris Delaney
    Chris Delaney Feb 05, 2018
    That model does not offer a back lit display.
    The display is only capable of black text on the gray background, it cant be changed.
    If you would like background of the display illuminated or a display that has more colors you should look into some of the new models they have out now.
    https://www.lacrossetechnology.com/produ...
My outdoor temp is slowing almost 10 degrees warmer than actual temp outside. What is problem.
You are using a wireless system that transmits signals between the outdoor sensor and the indoor receiver. They are not a perfect match. You cannot make adjustments, thus if your lucky, the factory matched up the devices prior to the sale. You may contact Lacrosse for a replacement outdoor temperature device.
Jan 11, 2018 | La Crosse Measuring Tools & Sensors
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
How to set time zones on La Crosse Projection clock 3N6
https://www.lacrossetechnology.com/support/manuals.php
3N6 its the technology named , but the model you can choose can be find on this site .
Mabe the model and page are find on these pictures.
la crosse 3n6 Google zoeken
Feb 18, 2016 | La Crosse Projection Alarm Clock with...
Set time on la crosse wireless temperature state?
You have to set these, if you don't have a manual you can usually obtain one on line or contact La Crosse
Mar 11, 2015 | La Crosse Measuring Tools & Sensors
Can't shut off alarm totally. It goes off every day. How do I shut it off.
Push the "alm/date" button to display the date instead of the alarm time. If the date is displayed on the LCD, the alarm will not sound.
Jan 06, 2014 | La Crosse WS 9037U IT CBP Wireless Weather...
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. taylor.norman1@gmail.
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
Aug 21, 2013 | La Crosse Technology La Crosse C86234...
Getting grey background on documents when copying
If you are getting a grey back ground, this means you have the wrong setting- the scanner is seeing a 'photo' image. look at your controls for TEXT or LINE
Apr 17, 2007 | Epson Stylus RX425 Multifunction...
Measuring Tools & Sensors Logo
85 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
