One would hope that the shop that installed your remote starter would stand behind their work and correct this problem. Your other options are to troubleshoot and correct yourself, or take it to a qualified shop to troubleshoot and correct. Then take that bill to the shop that installed the remote starter for reimbursement.
Long history of problems with this shop. I would like to be sure I know what I'm talking about when I go back. Have spent well over $1000 to have previous prostart installed/repaired/replaced.
If the vehicle starts properly from the driver's seat (not using the remote start device), there is no question that the remote start unit is not functioning as designed. If you've already spent that much money, you may want to report this situation to the appropriate consumer protection agency.
SOURCE: keyless remote wont work, vehicle completely shut down
Hi Russell,
Absolutely no power? No dome light? No head lights? Nothing?
When you step on the brake pedal, no brake lights?
If true, start at the source and pop the hood.
This is going to be a bit of back and forth dialogue. I'll ask some questions and you get me the answers. That way we can get to the root of the problem. To save time, I'll ask multiple questions at a time. Here goes.
Try getting a jump, when the cables are attached does anything light up?
Does it turn over and start?
Does it do anything?
Comment me back with your findings
Mike
SOURCE: 2002 Dodge Grand Caravan Driver Door Lock/Unlock Switch
sorry not sure the 12v prob will help this swtich works on 5v off 3v unlock 1v lock single wire lock/unlock logic signals
I found wiring diagrams at
http://www.dodge.com/bodybuilder/2004/docs/wd/rswd/tc.pdf
it is 2004 but use the wiring diagrams to test the wires
(most likely to fail where they flex)
because it is using logic gates disconnect the plug at each end of the wire you are testing or the damn thing will find a few diffrent ways to trick you.
SOURCE: 2005 dodge caravan door locks no longer work with
how is named this fuse and where is it? I look below the hood, but nothing is write talking about doorlock! I also got this problem, it's not the key, the key's working good..the light and horn works when i active or desactive it....Also, my horn's working with the key, but not with the steering!!
Thank for the help!
SOURCE: Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and
remote setup with a separate remote fob. However, the 2004 to 2009 Dodge
Caravan and Grand Caravan use a combination key and remote on one
device. To program a new keyless entry remote for the 1997 to 2003 Dodge
Caravan, you must have at least one functional remote, which is
required to enter synchronization mode. To program the combination key
for the 2004 to 2009 Dodge Caravan, you must have two functional
combination keys. If you do not, you'll need to see an authorized Dodge
dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
Hope this help (remember comment and rated).
