SOURCE: maytag refrigerator MSD2758GEW divider panel hot to touch
What you could check is that the fan at the back of the unit, where the compressor is located, is working, as this could also cause a heat build up. The partition between the two sides does generally tend to get hot due to the door circuit, to prevent ice buildup around the door. But people tend to notice when something is different. You are also right to check for dust underneath the cabinet as the condenser tends to be layered. If you have already cleaned it all out then you have probably done as much as you can. If you are still concerned contact a fridge guy. Hope this is of some help.
SOURCE: Presto HeatDish Problem
DO NOT DISCONNECT THE BUZZER! This is dangerous and unsafe.
There is a design flaw within the unit. You need to do 2 things.
1. Clean the surface of the dish very thoroughly. You can use a pair of plier to bend the edges so you can pull off the front cover.
2. There are 3 screws to remove the back of the dish. One at the top and two at the back to remove the plastic back stand. Now drill tons of holes in the top of the plastic stand and down the sides. The more holes you drill the better. What is happening is the heat is building up at the top of the unit tripping off the heat sensor. By venting the top, this won't happen anymore. I have no idea why they didn't do this from the factory. The system has to have air flow.
Also, you cannot buy replacement parts from Presto. They are worthless.
SOURCE: Smells like burn't plastic.
This is for the LFP6152E electric heater. I called tech support (800.642.HEAT), and explained the problem. I was told it was a diode that went bad, and they're sending me a repair kit. I guess I'll keep this number handy for the next few years.
SOURCE: dust behind screen
2 ways. There are two access panels about mid screen on the sides of the cabinet. Or you can take all of the screws out and take the whole screen apart ,all the way down to the lens on the projector. It is up to you. If you are pretty mechanincally inclined then take the whole cabinet apart, as you will be able to clean more of the cabinet. Use a microfiber cloth to clean both the screen and the rear mirror. Hope this helps. I usually clean mine every three months or so.
SOURCE: grill not getting hot, fire not around burners,
We assembled our new Genesis E-310 yesterday. Went together nicely, but won't heat above 350 or so. It should get to 500-550 degrees withing 10-15 mins. Any ideas of what could be wrong?
