I changed internet providers after the ***** of my husband. I have no idea what the user name and password are.
Here is the Full Process to Reset:
http://www.gadgetvictims.com/2013/02/recovering-dericamcybernova-hd-ip-camera.html
If you want to reset your IP Camera to factory defaults, you can use the following 3 methods. After resetting the device you will lose all your settings except Client Settings.
Method 1:Hard reset/ By pressing the RESET button
Step 1- Keep the device powered on for at least 30 seconds to complete its normal startup.
Step 2- Find something like a pin to press the Reset button on the camera and hold it for 15 seconds to restore the settings to factory defaults.
Step 3- Afterwards release Reset button, and the camera will be restored to factory defaults after rebooting.
Note: Reboot process takes about 1 min, please be patient.
Method 2:By using Intelligent IP Installer
Step 1- Install the Intelligent IP Installer with the CD.
Step 2- Run the Intelligent IP Installer. Click Search to find your device.
Step 3- Select your Camera in UPnP device list, click Factory default on the right side.
Step 4- Type the username and password in the login page, the default username and password are both admin. Wait for the device to reboot.
If you changed the username and password before and forgot the username and password, you have to follow
Method 1, make a hard reset.
Method 3:By using Web-based Utility (management page)
Step 1- Open the web browser and type the IP address of the IP Camera into the address bar, press Enter. If you have changed the default port number is 80, Then type the IP address of the camera: new port number into the address bar of web browser.
Step 2- Type the username and password in the login page, the default username and password are both admin. Then click OK to connect to the device.
Step 3- Click SETTING -> BASIC -> Initialize on the left side, and then click Factory default to reset this IP Camera to the factory default settings.
Step 4- Keep waiting until the progress bar shows completion.
SOURCE: Hawking wireless router to reset password
If you press the reset button you only make a reboot.
To reset all the value to the factory setting you have to:
- Power off the device
- Hold the reset button pressed
- While you press the reset button put the power back on
Now your gateway address is again 192.168.1.254, login is admin and password is not present (leave it blank).
SOURCE: Can't Open Internet Explorer
You have to contact your service provider. That's a thing which is done by them to secure there internet service. They will give you the username and password. I evn tried that and they asked me to type the modem name and 'admin' as a password. For example, my modem is STstarcom. so the username wax starcom and password: admin.
Thank you.
SOURCE: What's default password and user name for Actiontec GT704WG
Default username is admin.
Default password is password.
I hope this helps!
Testimonial: "Thanks for the right answer!"
SOURCE: how to remove user name and password richo mp 4500
go to sp mode by pressing reset 107 then press stop for a few seconds then inter copier sp then inter mode then search for clear user .......then press it then press execute then tern the machine off the on i hope that well help u
SOURCE: way to reset the user name/password
You must have a smart card in plug in the rear panel of the UPS
