Toro Power Lawn Mower Logo
G
George McFarland Posted on Feb 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2007 workman 1100 jumps out of gear - Toro Power Lawn Mower
Clyde Ottaway
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Toro Master 1,669 Answers
  • Posted on Feb 07, 2018
Clyde Ottaway
Toro Master
Level 3:
Loyalty:
Answers
1669
Questions
41
Helped
490308
Points
2465
Check the spring on the shifter
2answers
Why does my 2007 1100 V-star die when I put it in gear?
Hi Don does the bike jump forward as of the clutch wasn't working? If so the clutch is stuck. To fix put thd bike in high gear and hold in the clutch push the bike back and forward with the help of a friend until it frees up. If this is not the problem check the side stand switch it might be faulty. If you have a doubt about the switch join the two wires together temporary to test. Regards Jim...
I have a 03 yamaha vstar 1100 classic and here latley when accelerating hard in second gear the bike seems like the transmission is skipping (not slipping)... any ideas as to what in the tranny is causing...
Sounds like a bent shift fork. While accelerating you can feel the power cutting in and out quickly. The problem will get worse if you keep pushing 2nd gear till it slips. You can learn where (at what RPM) it wants to jump out and start shifting before it jumps out. The long term fix is opening the transmission and fixing the bent shift fork.
Is it possible to safely jump start a 2007 yamaha 1100 v star?
You can connect a good battery to thr dead one and it will give tour charger a battery to charge until your dead battery gets some charge. You can now safely disconnect the good battery./
2002 V Star 1100 Silverado: i have a 2007 v-star 1100 clasic. drive shaft make...
when is the last times you checked or changed your diff oil? if it's good and fresh, your ring and pinion gear are bad.
3helpful
3answers
V-star 1100 custom stalls when dropped into 1st gear
Check the switch connected to the kickstand. A lot of bikes will not allow you to have the bike in gear when the kickstand is down and if that switch/relay goes bad, it can result in exactly what you are describing.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
