Televison & Video Logo
Sue Reinard Posted on Feb 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LG 60"flat screen TV.i turned it on this morning and it worked and about 15 sec the picture went out.tried switching channels and still no picture.chec
john smith
Level 2:
  • Expert 406 Answers
  • Posted on Feb 04, 2018
john smith
Expert
Level 2:
Answers
406
Questions
0
Helped
83937
Points
950
The power capacitors have likely blown on it. You'll need to repair under warranty or get a new TV
5 Related Answers
A
Anonymous
  • Posted on Jan 01, 2008
SOURCE: 27" Advent Flat Screen TV: Picture Missing but can hear sound
High Voltage. Check fly back Xformer.
Anonymous
  • 3 Answers
  • Posted on Jan 17, 2008
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
A
Anonymous
  • Posted on Sep 28, 2008
SOURCE: No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
gtaplytmpt
Andy
  • 90 Answers
  • Posted on Jan 04, 2009
SOURCE: LG Flat Screen TV has no picture, but sound
The times my TV at home has done this it is because I'm tuned to an HD source and my TV doesn't have HD. Or vice-versa, I tune to a regular channel and I have the TV set to HD.
If you have NO picture, like the channel number or volume bar don't appear, then this isn't the problem at all.
I would say check the Video (Yellow) cable in the back, or try setting up and playing a DVD and see what happens. maybe cycle through video modes, Digital etc.
If none of this helps, comment on the post and we can exchange more information.
TStevens
  • 110 Answers
  • Posted on Apr 28, 2010
SOURCE: 47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
I have a 15 inch TV LG Smart TV something went out on it what could it be the model number is 50LN5700UH the LG light comes on but no picture
LG TV : Picture not coming on screen, but TV is on. - Forums - CNET
www.cnet.com > Forums > LG
CNETJul 14, 2014 - Dear All, Have a peculiar problem with my LG flat screen TV. It stopped working suddenly, that is no picture when switched on, I noticed the ... However, in my case the RED light keeps on blinking and there is a ticking sound ... LG Plasma Flat Panel 42PC3D - No picture just sound
Jun 11, 2015
No Picture from LG 50PS60 Plasma TV
Nov 16, 2013
More results from www.cnet.com
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... came on good with green light working properlybut still no picture.
My LG55LE5500 suddenly stopped working this morning. Last night, we switched it off in proper working condition. This morning, when we switched in ON, only the initial LG logo screen comes and stays there...
Check whether the product is turned on. I Try another channel. The problem may be with the broadcast. I Is the power cord inserted into wall power outlet? I Check your antenna direction and/or location. I Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in. From the LG manual kolbrun
Lg50pc1d purple screen
try to unplug the set for a period of time?
I have no picture on my 15" LCD Insignia TV. My
You may have a burnt out blacklight... You can fix it easy by having the tv on while it’s a bright picture than quickly unplugging it... or it would be best to get a new TV.
2helpful
2answers
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
1helpful
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
Viewsonic problem
Have you checked the SCART leads?
Usually seems to be the cause of this kind of thing.
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
