Edit: figured it out myself. Press "tv/video" and see if any of your input channels is on "beta". If one is, go to that one and that's where your fire stick works from. If one is not on Beta: 1) go to the "WEGA Gate" menu>>go to "video" 2) go to "change video labels" 3) pick a channel (preferably one that doesn't have a label or says "skip) and select it 4) scroll through the label selections until you get to "beta" and select it 5) exit out by pressing the "WEGA Gate" button 6) Press "tv/video" until you get to the Beta channel. It should have a screen telling you how to the pair the Firestick remote."
Fire TV Stick connections....
1 Connect USB cable into fireTV stick, and plug in power adapter. ...
2 Amazon fireTV stick and power adapter. ...
Connect fireTV stick to HDMI port via HDMI extender.
3 Amazon fireTV stick connected via HDMI EXTENDER CABLE TO Monitor HDMI port. ...
4 Turn on TV and select HDMI port
Testimonial: "No, thats just the instructions that came with the fire stick, which I already had. It speaks nothing to the setup of this particular TV. I did figure it out tho. Press "tv/video" and see if any of your input channels is on "beta". If one is, go to that one and that's where your fire stick works from. If one is not on Beta: 1) go to the "WEGA Gate" menu>>go to "video" 2) go to "change video labels" 3) pick a channel (preferably one that doesn't have a label or says "skip) and select it 4) scroll through the label selections until you get to "beta" and select it 5) exit out by pressing the "WEGA Gate" button 6) Press "tv/video" until you get to the Beta channel. It should have a screen telling you how to the pair the Firestick remote."
SOURCE: sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
SOURCE: Please help on cleaning the mirrors
It is not recommended...not even for a service tech unless there is a definite need.
I think some people think that this affect the picture brightness and cleaning it will help. I can tell you that after 3000+ units(not an exageration) this does not need to be done and it is never the reason for the dim picture.
You are more likely to leave smudges then remove any. In some cases you may get spider webs or large pieces of dust inside but it is best to just vaccum or blow these specific items out. You can look inside 90% of these projection TVs and it is enough dust floating to look like a blizzard. You can not get rid of it and it really has no affect on the picture quality
Basically, I dont' recommend cleaning by anyone. If you do, just lightly dust or blow out with compressed are while vacumming the floating debris.
SOURCE: Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
SOURCE: how do i reset the lamp life for sony KDF-E42A10 ?
1) In standby mode, press the buttons on the Remote Commander sequentially, in rapid succession:
[Display] , Channel [5] , Sound Volume [+] , Power [ON]
2)To enter BE-micro service mode menu, press JUMP 2 times.
3) To display the lamp time, press Channel[4]
The screen displays:
“ Total lamp time is 14 hours”
4) To display the lamp time clear, press Channel[5]
7 times and Channel[1].
To reset the lamp time press Channel[3] > [MUTE] > [ENTER].
WRITE (Character color is red) is momentarily displayed and the lamp time is reset to “0”.
This worsk for other Somy retroprojection TVs as well, eg. KDF-E50A10 , KDF-E50A11 etc.
If you goto eserviceinfo.com you'll get the whole service manual
HTH!
zioanza
You're welcome.... enjoyed
Glad I could point you in the right direction...
