Question about Precor Exercise & Fitness
Precor elliptical 5.33 won't turn on.
My Precor elliptical suddenly stopped working, and the console does not light up. Yes the outlet works, the power cord is good, and the power switch is flipped to the 'on' position. I removed the switch and tested the connections with a multimeter - which all work fine. I am wondering if it might have been a 'power surge' that created the problem. Does anyone have any advice about how to proceed with troubleshooting?
  • Precor Master
  • 1,594 Answers
SOURCE:
pixelsword
  • 7 Answers
SOURCE: playstation3 will not power on
Make sure your cord is in all of the way. Happened to me once (well, twice).
Posted on Jun 15, 2007
  • 631 Answers
SOURCE: Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Posted on Jan 28, 2008
  • 23 Answers
SOURCE: My Nintendo 64 Console stopped working
Make sure your cables are tight... take a q-tip with a little rubbing alchol and apply to game cartidge and inside the N64 where the cartridge fits in... wait until it drys (only about 5 minutes) and then try it. Sounds like it's just dirty:)
Posted on Jul 07, 2009
  • 87 Answers
SOURCE: Power cord isn't working for Acer 5720
I have had a similar problem but not with this PC. Some power cords look the same but are slightly different in design. They may fit but often the cords are built differently and over time the pins wear and lose contact.
First, try another power cord from something you know is working. If this doesn't solve the problem then we need to look at the power supply itself.
That may have blown or overheated and cooked something (it happens). If the CPU fan is dirty with dust and you use the PC on non-hard surface ie. no air flow underneath, you will cook the thing.
The fact that the power supply doesn't light up indicates to me its simple power cord problem or a dead supply.
Posted on Nov 05, 2009
  • 691 Answers
SOURCE: My 2006 Chevrolet equinox cooling fans and front
I would find the circuit breaker relay that supplies power to whichever power distribution box that contains the cooling fan relays. If the box has power, then you may want to consider the following: I feel that if you find out why the fans quit working, then you may also have solved the front turn signal issue.
Electric Fan(s) not working, Checking the fan(s), relay, fuse and engine temperature sensor's.
Verify that the fans work by unplugging them and run jumper wires to the fan(s) from the battery. If they run, your problem lies elsewhere. If either does not run, it's the motor.
Next thing to check is for power at the fan connectors. You have to be cautious doing this because the engine needs to be running and warm if not almost hot, and the A/C also needs to be on. (Both must be on and running for the duration of this checklist.) The A/C fan is on the passenger side and should come on almost the instant the A/C is turned on. It is also the secondary engine cooling fan and should cycle on and off in relation to engine temperature, (If the A/C is OFF). Use a test light to probe the two wires on each fan. If you find power, the fan motor(s) is/are probably bad. If there is no power to fans, roll up your sleeves!
The temperature switch is usually located above the oil filter. If the dash gage is working, its probably OK. Next is the Fan Control Temperature Sensor, located IN or CLOSE to the thermostat housing. You will find out if it is working later is this checklist. I just wanted you to know where it is. Next is the relays and fuse's. Usually located in the engine compartment on the passenger side power distribution box. You will need to remove anything over the cover to open it. If the fuses are OK, tap on the relays or pull them out and push back in. If the fans are still not running, pull a relay and probe the socket terminals for power. Two of the terminals should have power, usually criss-cross from each other. One hot terminal is battery power, and the other is the "signal" voltage which triggers the relay to send 12V battery power to the fan. This signal voltage comes from the sensor at the thermostat. If only one terminal has power, then I would replace the sensor at the thermostat, if not both sensors.
Posted on Aug 19, 2011
Precor elliptical says stuck key on upper display and sometimes flickers or doesn't even turn on at all.
A stuck tek generally means the hard overlay (with buttons) is faulty. I have seen where the entire console needed to be changed. The battery may have also been bad but this would have been for the flickering only.
877-805-1030
Book An appointment
Mar 09, 2016 | Exercise & Fitness
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
My precor 517.1 elliptical does not turn on
I would start the troubleshooting process by confirming power at the wall outlet. If this checks out, follow power from the wall to the end of the cord. If you still have power at the end of the cord, check the power inlet. If you still have power on the back side of the power inlet, you may be looking at a bad control board. Repair Parts for Precor 5 17 5 17i Ellipticals Consumer SPORTSMITH net
Sep 28, 2014 | Exercise & Fitness
No power, when I turn the switch on, the power lights do not display
Look on the back for a reset button, it could be a small red button the size of pencil lead protruding slightly, push in on it. It could also be located in side a small hole the same size use a tooth pick or something none metallic to push with...
Jan 09, 2014 | Precor EFX 556 Elliptical
Precor elliptical keypad replace
Step 1:
please see the video for help in dissasembly the elliptical keypad replace.
Step 2:
please SEE the detail for dissasembly the console in elliptical.God bless you
Console
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Jan 07, 2013 | Precor Efx 546 Version 1 Lower Body...
Won't turn on
Check the battery and or power cord for the proper voltage.
Video about How to Test Battery
Jan 26, 2012 | Precor EFX 546i Elliptical Version 4
A precor 5.21 elliptical exercise machine has died after a move. Display is dead and lift motor tries to go up past the breaking point. Disconnecting console stops lift motor execution. I need a...
According to your requirement contact visit www.sportsmith.net/images/product_support/precor/Service%20Manuals/Consumer%20EFX/5.21i%20(serial%20code%20SS).pdf and download the manual, it will help you to repair the machine. You can also visit www.navisan.com/Articles/EFX521SRepair.aspx. Here the article may also help you. But first check the electric outlet and the electric input of the machine.
May 20, 2011 | Sport & Outdoor - Others
My precor efx 544 has stopped recognising that i am using it. does not display strides or calories burned. any ideas?
My Precor Elliptical EFX 546 Timer Stops After 7 Seconds, what is wrong? The most common cause for the Timer to Stop After 7 Seconds on a Precor Elliptical is NO RPM Feedback.
Knowing the status of the unit from its last use as well as the last service or part replacement is a great place to start.
Check the connection of the speed sensor to the lower board. Reset connection if necessary.
Check the magnet. The magnet is located on the user's right crank arm on versions 1 and 2 and the user's left on version 3. The magnet passes the speed sensor with each revolution of the crank arm. The magnet should be installed so that its south pole is facing the speed sensor. You can check the magnet polarity with another magnet that has marked poles or a compass. The north pole of the marked magnet or the south facing needle should be attracted to the magnet. Correct magnet installtion if necessary.
You may also check the spacing of the speed sensor to the magnet. The spacing should be 1/8" to 1/4". Adjust if necessary.
Also see the following link for additional information.
Replaced Crank Arm on Precor EFX 546 and Display Doesn Work
Jan 14, 2011 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
591 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
