When was the last time you cleaned out the vent line? I do it with a shop vac and several extra hoses taped together. Yours obviously is clogged.
The THERMAL Switch is detecting values higher than normal. This is to keep your dryer from over heating and causing a fire. This feature is a PROTECTION built into the dryer circuit and indicates you have a bad dryer heater needing replacement. At some point, you may be blowing a circuit breaker which is the second line of defense. Rather than having a FIRE...get a repair man to fix the Dryer NOW!
SOURCE: hotpoint wd440 washer dryer fault
sounds like the heating element of the dryer may have come loose and is shorting against the metal dryer box on top of the drum.
engineer job if you're not electrical
