SOURCE: bulb keeps burning out
There are several reasons for short lamp life. Inadequate ventilation or clogged cooling fans, a bad lamp driver or lamp ballast (they are the same) and the use of non-original Sony lamps, as the aftermarket replacements are known problem causers. Remember too that the number of times the lamp is turned on and off is a BIG factor in how long the lamp will last.
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If
there's no obvious removable cover over the bulb (most often on the
rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a
microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
If you don't have your
instructions, please reply back with your brand and model number.
Once it's out of the
wall, the outer cover (wrapper) will need to be removed, just as you'll
need to do on a counter top model.
On a
counter top model,
be sure it's unplugged, but otherwise ignore the instructions
above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
Bulbs can be had locally in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
Many models use halogen
lamps. You must not touch the new one with your bare skin, as the oils
will shorten the bulb life.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: power light blinking and housing for lamp screws broken
I bet the area around the lamp shows signs of warping and/or cracking too? This is a VERY common issue as the fan that sits above the lamp gets clogged with dirt which allows the lamp to over heat which decreases the lamp life as well as distort the plastic casing around the lamp. The fix is a thermal fuse kit and a new fan and of course a good cleaning of the other fans in these TV's. This should be performed by a service technician.
SOURCE: Our TV keeps burning out the bulb. The first time
Seek a repair shop. You most likely have a ballast power supply issue.
SOURCE: sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
