Question about Casio Watches
How do i change both batteries on my Casio forrester 5405?
Nobody knows how to change batteries on Casio Forrester 5404. Why?
changing the battery in these watches is difficult if you do not have the correct tools. Take it to a jeweller or you will damage it.
Feb 02, 2018 | Casio Watches
Casio forrester date will not change
https://www.youtube.com/watch?v=I9VGeriSTOI CASIO FORESTER
Jul 12, 2017 | Casio Watches
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
I need to change a battery in a baby g watch
mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
Jul 14, 2010 | Casio Baby-G Wristwatch
My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
Jul 12, 2010 | Casio Watches
I have a Casio DBC-60. I changed the battery because was not working for long time, but the watch stil is not working
This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
May 14, 2009 | Casio Watches
Casio Forrester watch FT-200
You can download a PDF manual for any Casio watch at http://world.casio.com/wat/download/en/manual/index.html
Enter the module number of the watch to download the correct manual. (It should be on the back of the watch. The module number for the FT-200 is 1879. The "module" is the "brain" or movement of the watch, and often the same module is used in several different watch models.)
Oct 24, 2007 | Watches
Watches Logo
1,329 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Casio Watch Expert? Answer questions, earn points and help others
