SOURCE: Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
SOURCE: PS2 controller lag for rock band
On some home theater systems and TVs, there is a delay between what you press on the controller and what you see on screen.
There are three possible solutions:
1. In the options menu, you can "calibrate the lag". It may or may not work, but it will most likely reduce the lag.
2. If it's a HDTV, buy a PS3, with the PS3 version of the game, with PS3 controllers, and use a HDMI cable.
3. Play on a smaller, older SDTV (480i).
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
SOURCE: how to master clear the handphone 9502 beside
Sorry for having read your post that late. I think you have already sorted it out by now. Anyway, in order to hard reset the 9502 by hardware means, press and hold both the blue Fn and the green phone buttons, and, at the same time, press the reset pin with the stylus pen. A white screen will come up asking for confirmation. Just confirm it (with the left softkey, if I'm not mistaken).
Hope it works for you.
Cheers!
Carlos
