How do I use an Anker speaker with a Samsung tablet using an Anker audio cable
I have plugged the cable in to both the speaker and the tablet but no sound can be heard
5 Related Answers
scousemumble
  • 20 Answers
  • Posted on Sep 23, 2008
SOURCE: Samsung HT-TQ85 HDMI Input not working
I rember reading an article stating that the HDMI does not suppory audio
Zlatan Imamovic
  • 25 Answers
  • Posted on Aug 26, 2009
SOURCE: I just bought a Samsung
you must select on remote press "audio" an when appers music on dvd you will have surround sound
Anonymous
  • 304 Answers
  • Posted on Apr 16, 2010
SOURCE: Samsung UN55B8000 Audio out - 3.5mm connection not working
Try a firmware update from Samsung. If that does not work, replaced the Main bd.
Anonymous
  • 4044 Answers
  • Posted on Jul 22, 2010
SOURCE: Speakers/Audio problem
This isn't going to have anything to do with your speakers. It will be something in your system settings that deals with Internet or Video. Check your Sound card selections and your equalizer settings to make sure you don't have it muted somehow.
dj_relly999
dj_relly999
  • 4070 Answers
  • Posted on Sep 16, 2010
SOURCE: audio unlimited wireless speakers quit working.
Hi! The problem will be on the wireless speaker itself. I'm afraid that this is unrepairable for this units are disposable. Hope this shed some light.
Connections forZ313 Logitech speakers to ellipsis 8 tablet
https://www.logitech.com/en-ca/product/speaker-system-z313
The speakers have a 3.5mm stereo jack, does your tablet have a headphone output? Connnect a Male-Male 3.5mm stereo cable between the two, The Logitech does not have Bluetooth or USB, so if you do not have a headphone output, you can purchase a Bluetooth receiver, plug that into the Logitech with 3.5mm cable, and Bluetooth from the tablet to the receiver
My anker soundcore boost model A3145 is charged but up button lite and it will charge a phone if u plug into speaker but it will not turn on and play
Hello David ,
It is a good thing that the Device still charges .
I guess the Problem is Software related .
You may need to Perform a Factory Reset and or Firmware Update on the Device .
Note :
- You would need a Computer With WIndows on Mac OS
- Fast Internet Connection ...Wi-Fi preferably .
- Anker Update Tool .... which you would download fromthe Support Link below
Follow all steps as directed by the Update Tool .
Download : Link ...
https://www.anker.com/update-firmware
Post Result if this helps you ...to help other Users !
Good Luck !!!
Sep 27, 2019 • Cell Phones
My Samsung tv model number UA40C5000QF does not have a hmdi arc port and we have bought a Samsung sound bar but it cannot be connected as it does not have that port
Your sound bar can be connected to the UA40C500QF. Get an appropriate audio cable based on the sound bar. You'll either need a optical digital audio cable or an analog audio cable with a 3.5 mm plug on at least one side. (If your sound bar has an AUX input, then a 3.5 mm to 3.5 mm M/M audio cable is appropriate. Otherwise, you may need an RCA (M/M) to 3.5 mm audio cable or some sort of RCA to 3.5 mm adapter (F on one side, M on the other).) Connect this cable to the audio out on the TV (headphone or digital audio) and the appropriate audio in on the sound bar.
Set the sound bar source to the chosen input (Aux or Digital In (D.In on some systems). Next, set the TV to use External speakers. This is in the Audio sub-menu. The volume will now be controlled by the sound bar volume control.
You can still use the HDMI cable (HDMI out to any HDMI in on the TV) if you want to use the TV screen when changing the settings on the sound bar. Just change the TV source to that HDMI port with the Source button on the TV remote or on the TV (the left-most button on the front panel). Then change your source back to the video signal for the TV to view items connected to the other HDMI ports. If your sound bar has an HDMI input, you would similarly use set the TV to the sound input to watch that source.
I hope this helps. See the manual for the UA40C500Q for the details on setting the speakers to External speakers. The manual is available on the support page: https://www.samsung.com/au/support/model/UA40C5000QFXXY/ . The current link to the manual is http://downloadcenter.samsung.com/content/UM/201003/20100316163048500/BN68-02727A-00Eng-0225.pdf .
2answers
Speakers do not work. Headphones do. Tried adjusting volume but nothing changes
Possible causes are:
faulty conections on speaker cables, check all conections.
cable damaged, replace cable
speakers faulty, replace speakers
4answers
When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
How to connect speakers logitech z 5500 to the TV Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED
Hello there!
I have seen manuals of both the systems. You have two options to connect Logitech z5500 speakers to Samsung UN32F5500 TV.
1. With Optical Audio Cable.
2. Stereo Ear Phone Connection.
Simply plug in Green earphone cable of Logitech Speakers to Green Audio out Jack described on Page 7 of the TV manual. If you are using stereo EP you may not experience 5.1sound separation. And it is also mentioned that you should not use other two audio cables of the tri-EP-cable provided with Logitech speakers.
Have a nice day!
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
2answers
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
