Transfer Belt Error Error code 59.FO. Replace the belt.
Don't confuse with 59.CO which is a machine problem, usually related to develop disengagement assembly. If someone has previously worked on it, then all it may need is a main assembly removal and replacement, with replacement being done to HP specs. (gear alignment and so on)
SOURCE: 59 C0 error on hp color laserjet 5550
59.C0error on hp color laserjet 5550 dtn
can you please suggest a solution for the above error on my printer urgenty
SOURCE: HP Laserjet CP2025
The yellow flashing light shows network activity and is quite normal. It flashes every time a message is sent anywhere on the network.
