MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
    Novelist:
  • 97 Answers
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Posted on Feb 03, 2018
4 Suggested Answers
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: During the spin cycle water pours continuously like fill cycle
This problem is commonly attributed to either a water inlet valve leaking by, or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I've included parts sources (if required) and how to repair each problem. If you have any questions, please post back and let me know. I hope this information is helpful to you.
Posted on Mar 19, 2010
  • 185 Answers
SOURCE: Dryer turns on and rotates. However, does not dry
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Posted on Mar 21, 2010
Testimonial: "Thank you. I will check this"
  • 1010 Answers
SOURCE: candy washer dryer filling water dry cycle then empty
Could be the circuit board at fault
Posted on Mar 31, 2013
Just bought the Crosley high efficiency washer. It does not change cycles.
The problem is that your new Crosley washing machine is defective.
Jul 04, 2018 | Crosley Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
The washer will fill up and go through the cycles, it will drain properly, but then the spin doesn't work proprerly. It does not spin at quickly, only very slowly and a knocking sound will occur. When...
Since you didn't say what brand and model you have I can only give you generic advice. If its a GE washer, it has a belt and sounds like it may be very loose or/and worn out. Other brands have belts as well. if it doesn't have a belt then a knocking sound could mean the transmission is out.
May 15, 2011 | Washing Machines
Mar 19, 2010 | Washing Machines
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
I am very unhappy with this machine and sorry I bought it! It uses so little water that sometimes when I take the clothes out after it is finished washing I can see dry spots on the clothes that never even...
How about putting the clothes in and pouring water over them with a jug before the washer starts its program ?.
It could also be that the water level switch is out of tolerance and needs replacing
Most machines have a pre-wash cycle as well
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Some clothes not clean or even completely wet after wash cycle finished
Ebay item number 200262803398 is a cheap PDF service manual for this model.
prem
Oct 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
