Most lenses can be unscrewed internally but you have to remove the plastic bezel on the front of the lens. it is a thin plastic ring around the glass that covers the internal threads of the lens barrel. If the loose element is in the rear, it may unscrew from that end. Not really a job for a novice but can be done if the lens is useless as is, no harm to try. If it is an expensive lens, you may want professional help. If the lens is not removeable (bridge camera) you can try through the front.
SOURCE: suitable teleconversion lens for fuji finepix s5600
Try the website for a company called "Raynox" (www.raynox.com). They have various tele lenses and the required adapters. Fuji doesn't make them any longer. I can't tell you about the availability in India, however, because I'm in Canada. Another solution may be to try ebay.
