SOURCE: how to light a American Standard furnace
If it is an old furnace with a manual pilot light there are pilot lighting instructions usually on a door or panel. If it is 15 years old or newer it probably has either a spark ignition or a hot surface ignitor. These can't be lit manually. If they fail they usually require parts to be repaired.
SOURCE: lcd panel will not come on
Need to exchange the Main Board.
If you are in Vancouver, BC?
Please contact 778-893-8792 Jay Lee
SOURCE: American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
SOURCE: miller propane furnace .red light flashes 5 times
furnace fan dont shut off then it will not work until you push a reset button what is wrong with it.
SOURCE: Just had an American Standard Freedom 95 furnace
Most furnaces have a tech manual inside. Under the blower cover should be a trouble shooting guide. Call the dude and tell him what the problem is. You have no other source of heat and you live in alaska?. If I was you I would invest in a comfort glow gas vent free heater for emergency. No power is needed to operate the heater.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
