Hello, Tracy -
See your earlier question and the answer by Sock Puppet here:
http://www.fixya.com/support/t26874371-connect_speaker_wires_no_plugs_logic
Note: You could have gone to your Fixya.com account and looked at your earlier question and seen the answer by Sock Puppet.
Best wishes.
SOURCE: New speakers to an old (1960s) record player
It is difficult to say with 100% confidence because the pictures are out of focus, but it looks like you have just a regular turntable. The wire connections you show are the bridge between the tonearm and the external RCA style cables. The extra wire (#5) is the ground wire. You should be able to connect this to any receiver that has a phono input.
For confirmation, can you update this with the model number of the turntable? That will allow me to confirm what I have stated above.
Thanks,
Dan
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
SOURCE: Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Testimonial: "Thanks that was GREAT!!!!"
