SOURCE: broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
SOURCE: Jenn-Air dishwasher model DW871UQB. The upper
check it when you have it off may be blocked with particles causing water pressure to throw it off
SOURCE: Frigidaire dishwasher PLD2850RDC2
i DON'T KNOW IF THIS IS A SOLUTION OR NOT. My DW (same make and model) came off after being knocked off with an overly tall dish load. But, in addition, the 'nipple' gasket (looks like the nipple for a baby bottle, pretty much) was broken. I attahced it several times, same problem. I am going to replace the gasket. I think it might be the necessary part to fix the issue.
SOURCE: upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Testimonial: "Wish one could buy just the clip and not the whole assembly, but it is not expensive."
SOURCE: how do you put upper arm and upper wash spray arm
just call me on +263912639492, thta's easy.thank you.
Dr. Kelson
