SOURCE: Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
SOURCE: how to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
SOURCE: sony laptop won't detect hard drive
Did you config as primary or slave?...jumper setting?
Try entering BIOS before your Operating System begins to boots up.
BIOS must recognize it before Windows ever will.
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
1. Check to make sure you have the MSXML Parser 6.0 installed:
If this is not found, visit Microsoft's website to install this component: http://www.microsoft.com/downloads/details.aspx?FamilyId=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
- Open Control Panel
- Open Add/Remove Programs / Programs & Features (Vista)
- Check box for "Show All Updates"
- Look for "MSXML Parser 6.0"
2. Make sure Microsoft .Net Framework 3.5 installation
- Look for "Microsoft .NET Framework 3.5".
If this is not found, visit Microsoft's website to install this component. 3. Try the steps listed here.
4. Remove the Seagate folder from C:\Documents and Settings\All Users\Application Data (XP) or C:\Program Data folders (Vista) and reboot.
5. Download and install the newest Windows Installer.
6. Download newest Seagate Manager from our Website and re-install a clean copy. Note: Do not do the update when the message pops up saying one is available.
The firmware for any electronics device tells the hardware how to properly function.
Most devices rarely need a firmware upgrade, however, computer products such as a Seagate hard drive need to have the firmware updated periodically due to computers constantly going through operating system upgrades.
Luckily, you can update your Seagate hard drive firmware with an Internet connection and a few clicks of your mouse.
Connect your Seagate hard drive to your computer if the hard drive is external.
Launch your Internet browser and navigate to the Seagate.com website.
When the site loads click the "Downloads" button.
Click on the hard drive listing you currently own.
This brings up all of the most current downloads for your Seagate hard drive.
The listings of the hard drives have the image, so match your hard drive to the image online if you are not sure what drive you have.
The user manual states what hard drive you currently own also.
If you don't have your owners manual, open "My Computer" (or "Computer") and right-click the hard drive icon and select "Properties."
Here the computer states exactly what model of hard drive you have.
Click the Firmware update and click the "Download" button to launch the download.
Click-and-drag the file into the hard drive if you are using an external hard drive
(open "My Computer," then double-click the removable hard drive icon).
Open the downloaded file and follow the prompts to install the updated firmware.
Hope this helps
