SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
SOURCE: Adjust stride length
I went online and used the Omron manual again. I had tried it before and it didn't seem to work but just persevered and had success.
SOURCE: Where can i get a
Good day,
You can download your needed manuals in this site.
http://www.precor.com/comm/support/owners/
Hope this helps,
and thank you for using Fixya.com
SOURCE: precor efx 5.17 which intermittantly stops counting strides and freezes the display
please follow this steps: Remove the bolts or screws
securing the console to the upright assembly. Lift the console and
confirm that the cable connections are secure. Remove the cover from the
console's battery bay and install a fresh set of batteries. Replace the
battery cover. Detach the ends of the pedals
from the crank axles. Remove the left and right disc shields and side
shields. Inspect the interior of the base unit and locate the flywheel. Inspect the flywheel as it
turns. Locate the magnet installed on the flywheel. Turn the flywheel
until the magnet passes in front of the nearby reed switch. Loosen the
screw securing the switch in place. Rotate the switch to reduce the gap
between it and the magnet. Tighten the screw.
Step 1
Step 2
Step 3
God bless you
SOURCE: How do I adjust the stride length down?
To resett, rekove the battery but you will have to read the instructions to set up again, as stated above. Unlesss you can work out the functins yourself.
GPPD ;ICL
