Vacuums Logo
Wanda Anderson-Seger Posted on Jan 29, 2018
My vacmaster PRO 130 When plugging it in I hit the on button it says E02 on the screen. What do I Do ?
Fionn
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 29, 2018
Fionn
Contributor
Level 1:
Answers
Questions
0
Helped
719
Points
11
First off, check the manual that came with the vacuum. In the 'Troubleshooting' section, there is a list of error codes specific to your model. If you don't have the manual, I'd suggest making sure the vacuum conduit (the 'tube') is clear of debris. String, thread, pet-hair... loose, stringy material may snag and clog the vacuum. use a utility knife to cut it free before testing.
2 Related Answers
Bruce Buesgens
  • Posted on Sep 15, 2013
SOURCE: My Vacmaster Pro 130 does not vacuum. What is wrong?
HELP I have vacmaster pro 130 and the vacume pump runs and it will not pull a vacume.Theres no packing part left and or pressing down on it will not help.It seems that the pump is not hooked up becouse it run but not pull a vacume.And it shows E01 on led screen WHATS WRONG
withteethhmb
Heathermichelle Briant
  • 20 Answers
  • Posted on Jul 01, 2014
SOURCE: Wire diagram vacmaster pro 130 wet dry vacuum
go to retrievo.com
What is the f-1 setting mean
I found the operators guide for the Vacmaster VP320 but do not see a reference to the F1 setting.
http://www.webstaurantstore.com/documents/pdf/vp320_manual.pdf
I found this information related to a different model of the Vacmaster:
If you see F1 displayed on the LED screen and the machine will not function, make sure the lid is open and turn the power off. Turn the machine back on and it should return to working order.
F1 code for oven
Vacmaster VP 320 is flashing F1 not working
Vacmaster 215 has F-1 dsiplaying
F1 PROBLEM ON VACMASTER VP540?
1helpful
My vacmaster pro 160 does not seal bags
Try with a different bag ( I have the same problem, the bags are not the same) if still not working, the you have faulty pump
My vacmaster pro 90 is not vacuuming
please test if the :a) hose is clogged b) bag/tank clogged or full you need replace or emptied
2) test the belt for broken or wonr, and replace.
God bless you
2helpful
3answers
Karen, I am the social media coordinator for ARY VacMaster. Most times when this problem arises with a new machine, it's because there are packing spacers on the under side of the lid that weren't removed. Pull those off and try again. If that doesn't work, Give our technical support department a call at (800) 821-7849. You can always "like" us on Facebook (www.Facebook.com/aryvacmaster) and ask questions to us directly there too. Hope this helps. You can contact me there for quicker answers. :-)
Top Vacmaster Vacuums Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Vacmaster Vacuum Expert? Answer questions, earn points and help others
