PEOPLE, YOU MAY DON'T NEED TO BUY T-CON CARDS OR ANYTHING LIKE THAT, THE FIXING FOR THIS PROBLEM COULD BE VERY EASY, MOST OF THE TIMES IS A FAULTY CONTACT IN THE RIBBON CONNECTOR THAT FEEDS THE LED SCREEN AND THIS FIX APPLY FOR SO MANY BRANDS, MODELS, OR SIZES OUT THERE, GOOD LUCK!. DISCLAIMER: THIS VIDEO IS FOR REFERENCE ONLY AND I WON'T BE RESPONSIBLE FOR ANY FURTHER DAMAGES OR INJURIES YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!. THANKS FOR LOOKING.
SHOW MORE
HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55 MODEL LG 55LX6500
SOURCE: I have a lg 50px1d 50
Sounds lik a bad buffer board. you will probably have to have a tech replace it.. could be big $$$. get an estimate first.
SOURCE: Replaced the T-Con board and
Can you please tell me if you also get lines on the screen with the old old T-CON board also?
Are they solid color lines?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
SOURCE: Hi, my 42" LG TV
Hi, the appearance of black streaks on the screen of a Sharp LCD TV is common problem most customers will have to contend with. One of the most visible signs is the appearance of a message that reads " loss of sync". In this situation, the individual will still hear the sound coming from the LCD TV but the picture disappears especially within 10 minutes of putting on the TV. In some other cases, small horizontal lines may develop on the LCD screen especially when an object is thrown at the screen -the horizontal lines develop at the spot where the object hits the screen, and these lines are often visible when the TV is turned on and such problem is characterized by Grey color screen with no pictures.
Another common situation is the appearance of vertical red line across the LCD TV screen. In this case, the connection from the internal ribbon connector and the display has been effected. This problem may degenerate into the formation of two screens which are separated by a black line .
LG TV screen repair for Black streaks on screen
The best possible LG TV screen repair for vertical lines on your LCD screen is the replacement of the screen itself. It would be ideal for you to know the warranty status of your LCD TV before returning it to the manufacturer. In the case of the formation of black streaks on the LCD screen, a possible reason is that one of the substrates in the screen has been fractured or it can be a result of the release of some bubbles within the screen, especially after the screen was hit by an object. You don't have to think much about this problem, as it should be in your best interest to get a LCD TV repair service to replace the screen for you.
In some other cases, some other components of your LCD TV screen might have been broken down { hardware problems} resulting in black streaks or the formation of Grey or black color on your screen, you will need to get your LCD TV screen undergo some diagnostic procedures before the problem is fixed. This will help you avoid future re-occurrence of the problem.
Thanks for using fixya.....
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in ShopJimmy.com (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Thanks.
