Use to pop in after a while but now nothing just spinning circle
Hello There,
You have not mentioned which operating system are you using i.e. win 7, win 8 or win 10.
First need to understand that you see a spinning circle at which stage, what do you see behind spinning circle, blue screen or black screen or windows logo.
Try to follow below steps hope that help you to fix the issue:-
https://www.easeus.com/todo-backup-resource/fix-windows-10-stuck-at-login-screen-with-spinning-circle.html
If this does not help then revert back.
Regards,
Sunil
SOURCE: Ihave ASUS M2N68-AMSE2 nmotherboard- on
hardware related issue, check your bios settings to see if halt on errors in enabled, also disable
the ASUS splash screen, you should be able to see the initial boot error..
