SOURCE: looking for a replacement electrical cord for a 6
I have good luck looking in the yellow pages for "Appliances-Supplies & Parts" for a parts store. If you have one close, take the roaster with you to see if they can match the cord end
SOURCE: need to install new leather knob cover
Hello, I can help you with this. With a tiny screwdriver you gently pry up on the button in the middle of the old knob. Work slowly, pry up a little at a time on the front and then the back until the button comes out. Back and forth. If you look inside you will see a snap ring, you can use snap-ring pliers to remove it or some sort of sharp pick or a screwdriver, CAUTION, when it releases it may spring into outer space never to be seen again. Then just pull the old knob off and install the new one. Good luck and if you have any other questions about this just leave a comment.
Testimonial: "Just got the Vette and am trying to fix a few of the worn parts. Advice worked great!!"
SOURCE: Need a power cord for a Nesco model 4946-10 6 qt. roaster oven
You can find replacement cords for counter top appliances at most hardware and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you get the correct cord.
SOURCE: i need a new black
You can order a new black temperature knob online from the following site:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=2257&secid=87&linkon=subcategory&linkid=104
If you feel your warranty is still in effect or product was defective you could try contacting West Bend. For contact information, see:
http://www.westbend.com/finditem.cfm?itemid=3230
