Underhood Electrical Center or Junction Block Replacement
Removal Procedure
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
Click to Enlarge
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
SOURCE: replacing battery in 2003 chevy Impala steps needed
get the right size wrench that u need and remove the cables off of the battery take out the battery put in the new put hte black cable on first and then the red make sure there good and snug but dont overtighten them
SOURCE: Can not find 2000 Chevy Cavalier Flasher Unit
the relay unit is under the dash near the steering wheel should be connected to the searing shaft it looks like a small square green or black the relay is about 35$
SOURCE: diagram for under hood fuse box
YOUR FUSE BOX UNDER THE HOOD IS LOCATED BESIDE THE BATTERY RIGHT SIDE THAT IS AWAY FROM THEWINDSHEILD, ITS A BLACK BOX RECTANGLE SHAPE IT HAS A COVER OVER IT SNAP THE COVER OFF AND YOU WILL SEE THE FUSES
SOURCE: I NEED A DIAGRAM OF THE FUSEBOX AND RELAY BOXES
On the cover of the fuse box indictes what each fuse/relay controls
SOURCE: FUSE BOX F450 2006
This information can be found at www.flmowner.com
You just need to give info for year, make and model.
After that choose owners guide. The pages you are looking for are 208-9. The printing is a bit small. I hope this helps.
