SOURCE: I need to replace the bent shaft that the chuck screws onto
I would go direct to Dremel.com or call them at 1-800-437-3635 and get the schematic and parts you need, I just checked and they have a parts diagram online that you can view. go to the section about manuals/literature and type in your model number. Good luck
SOURCE: dremel 400 xpr stopped working.
It could be the fuse between the brush and variable speed control switch. I have the same problem and found the fuse blown. I am hoping that I can replace the fuse without having to buy the complete speed control unit which is about $17.00 from Dremel. If yours is still under warranty you could send it back. If I can find a fuse for mine I will let you know where to get them. joatmontag
SOURCE: Dremel 395 rotary tool - not working
it is the coupling inside of it called a flex coupling and it seem s like it is made of wax or something. tomorrow i will go to home depot to see if they carry metal ones that won't break.
SOURCE: should I be lubricating my dremel (395) tool?
Just a comment-Based on experience, I would go with BOTH their suggestions and order brushes and bearings. That squeal is definitely the bearing; it is a sleeve bearing; RPMs too high for a ball bearing to last and the sleeve bearing has a solid lubricant cast into it.
SOURCE: I don't know how to change the bit on my dremel
Push the pin on the side next to the tip and hold it while Your wrench is turning the hex shaped piece around the bit that is what is holding your bit in. this should help as i am a proud owner of a Dremel. Hope this helps . if you have any further questions write back.
