You have two drawers side by side that are called the crisper bins and one long drawer at the bottom typically called the deli drawer. I think what you are asking is how to separate the front (clear part) of the drawer from the back (white part) ,right?
Usually there are snap tabs that need to be pushed in to release the two pieces but I need to say that they are very fragile and break quite easily so be careful!
I would try soaking the drawer to get whatever it is cleared from it and let it dry completely. Keep in mind that there is usually a left and right specific drawer so if it doesn't fit then do not force it!
SOURCE: Removing the refrigerator drawers from the Electrolux side-by-side refrigerator
Got it. My mother got one of these fridges and was frustrated with the drawers not sliding off to clean. It is designed to dissamble the complete drawer assembly. Start by removing the glass from the top of the chill zone drawer frame. Next grasp the white piece of plastic that the chill zone is written on and pull up. There are 4 pegs which affix the drawer assembly to the fridge. The front two pegs will pop out and then the rear will easily pull. The top drawer assembly must be removed before the bottom two drawer assemblies can be removed.
I also noticed the plastic pieces and tried to pinch them but I couldn't get them to budge. Once I saw the 4 pegs, it made sense.
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
SOURCE: I am also trying to remove a Moen single handle
the white plastic clip needs to be removed. squise the clip together and push it out at the same time should come out fairly easy, then just pull the black piece off.
SOURCE: Popped a key off my Dell Inspiron laptop keyboard by accident.
You should be able to just pop off another key from your keyboard using a flat screwdriver. Then just compare how that key looks and reassemble the plastic components and the key just snaps back on. Also you may want to check your warranty at support.dell.com under warranty status and enter your service tag. If you are under warranty dell will replace it. Also ebay dell keyboards are cheap to buy and easy to install just two screws and a simple cable. If you need more help let me know.
