I have internet connection to the wii
Find your utube logo then log in if that doesn't work / remove utube app from your wii and reinstall it then log back in / (using xbox i have to pay for xbox live account allowing me to use utube)
Nintendo has discontinued the Wii service. It is more than likely there are no new updates for the Wii YouTube app. the Wii will no longer be a viable device on the internet and not usable.
YouTube updates there site to keep up with new technology like the WiiU, Switch and the Wii has become unsupported by youtube so they can focus on the new system.
SOURCE: im having a problem w/my wii
Is it not getting an IP from the Router? Try resetting the router and see what that does...
SOURCE: windows live Messenger 2009 on vista disconnected internet
well, i guess windows live messenger should not be the reason for this problem, because there is no reason for the program make drop the connection.
you should check your router for any security option that can be blocking windows live services, and unlock all windows live services from you firewall protection or resident anti virus protection .
usually, problems like these are due to anti virus blocking some entries from windows live and dropping the connection for ''security'' reasons.
SOURCE: My wii console won't come on. We've disconnected
In order to setup the Nintendo wii console...
First i want you to visit this link for complete setup information,...
With specific guidelines & instruction...
http://www.nintendo.com/consumer/systems/wii/en_na/system.jsp
In case you need further help , you can revert back to me...
Regards ,
HARSHIT
SOURCE: Can't Reconnect to Secure Wireless Network
there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
SOURCE: wii lost connection to internet how to reconnect
FIRST, you want to check and make sure that your router is working and sending a network signal. When you find that it is and your Wii still won't connect, try moving your router to a better location where the wii can receive the signal more clearly. Then go to the Wii "Options", then Wii "Settings, Scroll through screens to "Internet" option, then "Connection Settings". Choose your Wireless Connection that you were using and do a "Connection Test". Sometimes it's only a matter of a couple of feet and the signal won't be strong enough, especially if the Wii and the router are in seperate rooms. If all else fails, simply clear the settings for the wireless connection you were using and start from scratch by re-entering the connection settings for your home network. Hope this helps!
