SOURCE: HP photosmart R707 camera does not turn on and charge
I Recomend you to charge your camera before it reaches the lowest level of charge displayed in the LCD Screen This might help the camera to turn on again after long usage but this is something you must take in consideration before it gets ruin but if it is already ruined and you have good luck you might be able to turn it on again and then you shall follow my advise.
SOURCE: battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
SOURCE: Jabra bt250v Indicator light doesn't remain on...
i have just repaired my bt250 with this problem, i hadn't used it for around 2 years and when i put it on charge just got i flash of blue led. the fix was to "jumpstart it" the headset needs to se some sort of battery voltage to start the charging process, i stripped mine right down but that was just to fiddley. IF YOU DO THIS IT WILL BE ENTIRLEY AT YOUR OWN RISK AND I TAKE NO RESPONSIBILITY IF YOU TRASH YOUR OTHERWISE USELESS HEADSET. ok all you need to do is very carefully remove back cover (undo 1 screw and ease it apart). be very carefull as there are delicate wires inside. lift the inner part out slowly and you will see the battery.it has some orange tape around the end and there is a small circuit board attached to it with a small red wire and a small black wire. look at the battery and you will see under the orange tape there are to larger tags.these are the main battery terminals, peel back the orange tape just until the tags are slightly exposed. now you need to solder a wire to each of them and DON'T TOUCH THEM TOGETHER. on the battery it says which tag is + and which is - make sure you mark your wires or get red and black ones. now i used the lead from the charger. look at it . it has a hole in the center of the pin that is the + so put the + wire in there. if you are not sure use a volt meter. now touch the - wire to the outer metal of the connector that is the - point on the charger connector. hold this for around 2 mins but no more. as the out put of the connector is 6.2v and the battery is only 3.7v the battery will get warm. if the battery is getting too hot in under 2 mins then take of charge. when you have done that and taken off the connector i recommend to use a volt meter and just put it on the battery wires you soldered on to check battery voltage. as long as it reads you should be ok. de solder your wires from the tags and rebuild headset then try and charge it. this worked for me. i am no electronics expert i just like to mess with broken stuff so i know it seems a bit dodgy to connect like this but i had nothing to lose and it worked.
SOURCE: sidekcik Lx will not charge.
alright..my sidekick does he same thing but i fund a temp fix....the guy at the store says its the charging port..idk.....first plug it in....let it charge 4 ten min....then try to put in on...it will say the low battery sign...dont worry...then t8 sumting pointy and push it in the little reset hole behind the screen as you swivel it...as soon as you see the little box with the circles in it you press and hold the space button... hopeully it will start by showing the four butttons....if it does start and cuts off at the tmoblie sign jus let it charge longer and do it agian....hopefully it will work on yours it worked on mine....gud luk
SOURCE: battery keeps loosing charge- kymco cruiser 125, 2005
I had this exact same problem on a hipster 125, it was a faulty regulator module ( mounted under the seat) I also found a short circuit (somewhere) in the wiring loom between the regulator output and the chassis (probably what killed the regulator in the first place!) I cut and replaced the entire wire to save removing most of the loom and after testing reg to ensure it was dead i fitted a new one (about £60) bike charges and runs like a dream now even with fully lights approx 80% of the time. good luck
