Question about Leisure Pool & Spa
My leisure bay hot tub flashes the code OH for overheated however it was only 102 degrees. We shut if off overnight but it still won’t reset.
    Top Expert:
  • Leisure Master
  • 9,985 Answers
Check recirculation pump and heater element and temp sensor
Posted on Jan 30, 2018
SOURCE:
  • 77 Answers
SOURCE: QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Posted on Apr 22, 2009
  • 93 Answers
SOURCE: when we plugged up our leisure hot tub it smelled like plastic bu
SMELL IS USALLY DUST ON HEATER TUBES TO BE SAFE FEEL CORDS AND LOOK AT RECEPTICALE FOR BURN MARKS WHAT TYPE OF TROUBLE WITH OTHER ITEMS
Posted on Jun 10, 2009
  • 37 Answers
SOURCE: i cannt trun on my great lake hot tub it is
either filter issue or temp sensor
Posted on Oct 11, 2009
  • 366 Answers
SOURCE: Reads OH but still cold
you either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
Posted on Mar 20, 2010
kel1guy2002
  • 3740 Answers
SOURCE: where can i get a
All of Lesiure Bay manuals are listed here:
http://www.spasbyleisurebay.com/ManualSearch.aspx
For reasons that make little sense... they are listed by a name vs a model number.
Polysteel Manual 0.93 MB Jun 2007 Celebrity Manual 0.74 MB Jun 2007 G-2 Manual 3.39 MB Jun 2007 B and C Manual 1.77 MB Jun 2007 DMI Manual 2.12 MB Jun 2007 C Series Manual 1.89 MB Jun 2007 Overseas 5S3 & 9G3 Manual 1.60 MB Jun 2007 Overseas Eclipse English Manual 0.26 MB Jun 2007 French Celebrity Manual 0.43 MB Jun 2007 German Celebrity Manual 0.43 MB Jun 2007 English Celebrity Manual Overseas 0.43 MB Jun 2007 Spanish Celebrity Manual 0.42 MB Jun 2007
Hopefully you can solve the model number mystery and locate your manual using the link above.
Thanks for choosing FixYa,
Kelly
Posted on May 22, 2011
I have a Leisure Bay hot tub but cannot figure out how to drain it. Number D2 1874
should be a garden hose down at bottom either exposed or remove front panel by controls or pump out with simer or cover pump
Mar 25, 2018 | Leisure Pool & Spa
I bought a used Leisure bay Proshield hot tub and looking for an owners manual
I found a link on Google to download the PDF format. www.thespasyndicate.com or www.SpaParts123.net.
Sep 28, 2017 | Leisure Pool & Spa
The OH Light keeps coming on although the temperature never exceeded 100 degrees.
check your recirculation pump it sounds like it isnt working or plugged filters
Oct 16, 2014 | Pool & Spa
Where can i view a leisure bayhot tub manual?
You can find a copy of the Leisure Bay hot tub owners manual on The Cover Guy website. We also have a guide for error codes and information relating to Leisure Bay hot tubs. Leisure Bay Spas Hot Tubs Information
Jun 11, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Leisure bay spa , will not go from SL mode , temp stays @ 82 degrees?
This appears to be the sleep mode, which is a freeze protection mode. You need to get your owner manual out and change the mode to standard so it will heat.
Rod
US Parts Center
Jan 05, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
OH display and still heating
OH is overheat situation. high limits should shut down tub after 108 degrees.....high limits are shot.....replace the circ board
Dec 02, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Mar 18, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
293 people viewed this question
Top Leisure Pool & Spa Experts
Kardoc
 steve
steve
Steve Slater
Are you a Leisure Pool and Spa Expert? Answer questions, earn points and help others
