SOURCE: Help with 4-line phones
i can answer the phone but cannot talk on the recv. it works the same on speaker as well. you can hear but they cannot hear me. i have changed out the headset, but its still the same. any help would be greatly appreciated.
SOURCE: intercom problem
make sure your wiring that connects lines from dmarc into the unit is consistant. Line1 must be line1 on all phones, line2 must be line2 etc.
After line appearance verified follow instructions in the manual and everything should work. If it doesnt contact manufacturer for assistance
SOURCE: INTERCOM
you need to have all the phones linked to the same wiring. for example, i just got mine working after working on it for some time. i had 2 of my phones hooked directly into my FIOS box and the other 2 were hooked into a remote location of the building. even though my thinking says they should be able to talk to one another, they couldnt. they have to be completely wired to the same wiring system with no interuptions so they can find each other in the network. then to use the intercom system, all you have to do is press 1-16 on your speed dial to reach out to the desired location
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
