What does the F90 error code mean on my gas range ShopYourWay
Unplug the power cord, or turn off at a circuit breaker.
SOURCE: frigidaire electric stove keeps beeping
IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
SOURCE: Frigidaire Gallery Self Cleaning Oven
F1 code on frigidaire is bad EOC (clock) Try shutting breaker off 20-30mins see if it resets itself.
SOURCE: Self Cleaning
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
SOURCE: my frigidaire gas range has a F90 on it when I
unplug the range.
wait 1 minute.
wait 2 minutes.
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
