Try plugging something else into those outlets and see if they work, or try plugging the mixer into an outlet that you know is working. If it still doesn't work it may be the plug on the mixer or broken wire on the power cord. Examine the power cord and look for any weak spots or damage to the cord or where the wires go into the plug. Usually the wires tend to break right where they go into the plug from bending or wear and tear. If that's the case all you need to do is buy a new plug cut the old one off and install the new plug.
SOURCE: Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
SOURCE: LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
SOURCE: Traeger BBQ trips circuit breaker
Mine is doing the same thing, but it does it within seconds of turning it on. I'd assume you as well have the digital thermostat. I've narrowed it down to what I believe is the hot rod igniter (or the purple connector). Unplug it and it should eliminate tripping and order new part or get warranty part.
SOURCE: ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
SOURCE: Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
