Washing Machines Logo
j
jack smith Posted on Jan 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint WML540P washing machine runs for about 3minutes, stops and then runs for another couple of seconds and repeats for a few times
Ken Strite
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Jan 26, 2018
Ken Strite
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
Helped
35120
Points
259
Sounds like normal operation for a newer model washer. They don't agitate nonstop like the older models do. Do the lights go through the entire cycle?
5 Related Answers
Anonymous
  • Posted on Jun 19, 2008
SOURCE: whirlpool calypso washing machine
Buy a new machine. We purchased ours from Sears 4 years ago, thank goodness we purchased the extended warranty, as Sears has been out numerous times to repair. In January 08, Sears replaced the pump only after they forced us to sign a waiver before they would even touch it, because my washing machine sits in a drain pan and they didn't install the drain pan. We signed the waiver (I need my washer) and the tech destroyed the drain pan and my my floor, basically she forced me to give her permission to do so. February 08 the extended warranty expired, June 08 the pump quit working again and Sears only warrantys part replacement for 90 days. BTW - the previous Whirlpool calypso model and Kenmore had a class action suit against them. Sounds like the newer models owners should do the same. Sears techs even told us to get rid of it. We bought a new one from Home Depot...
Anonymous
  • Posted on Oct 07, 2008
SOURCE: F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Anonymous
  • Posted on Mar 02, 2009
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Anonymous
  • Posted on Oct 03, 2009
SOURCE: GIVING ELECTRIC SPARK INSIDE THE WASHING MACHINE DURING RUNNING
washing machine motor sparks during spinning
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 10, 2010
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Hotpoint aquarius program won't start
Try this. Unplug unit. While unplugged, hold in power button for about 10 seconds. Release plug back in. See if that has reset the control module. Works on some other makes. Can't hurt to try.
Hotpoint wml540p
its a code look it up
Can you overide the lock system on a hotpoint wml540p?
Press and hold the end of cycle signal button for 10 seconds.Or try holding the start and cancel button together while starting the washer.
5helpful
2answers
Hotpoint WF645 error message: test
press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
1helpful
2answers
Cycles continues all day
Whatever the prob is, my advice to you is to call Hotpoint service for attention.
If you do anything yourself, you will make your guarantee null and void.
As it is only 6 months old, it will not cost you anything to get it put right.
Or ring the Hotpoint help line for advice, you will find the number in your handbook.
Please rate my advice to you.
Thanks.
3helpful
2answers
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
