Most android phones are rootable, however this phone seems impossible to root, i have heard of others doing it, but can not find any software that will do it
SOURCE: My phone software isn't smooth any more, I have
i had the same problem with my phone. The way i fixed it was to reset my phone i tried everything else but thats what i had to do.
save your numbers to your sim first and unmount your internal sd card in the settings before you do it that way you wont lose your numbers or pictures. Also if you have your calender set up with a google account you can sync your calender again after you reset your phone so you dont loose your calender. but make sure your calender is set up with your google account.
Once you reset it you will loose all of your apps but your phone will run smoothly and then you just have to watch out for the apps you download.
SOURCE: How do I root HTC
"NO. android is open source, which is why it can be ported to a winmo phone. windows is NOT open source, and so it cannot be ported back."
SOURCE: Its for ZTE SKATE. When i switch on the phone, the
sounds like a boot look put it in bootloader moded and do a factory reset
SOURCE: Unable to reset ZTE N762 phone
Hi,most smart phone has app's that comes with programs that protect your phone ,like your compurtor,It has to have a security I have a LG . One of my app's is a security app, call lookout and one section has a restoer,and backup, If you go to setting it might work, or juet pull da,/batt;and let it for a few.put, batt;/back in.
SOURCE: How can I root ZTE majesty window 7 android?
Its running android 4.1.2 which is Jelly Bean and is hard to crack, you could give Towelroot by geohot a shot usually works for a lot of devices.
