SOURCE: leaking water from bottom of tub
this is bad it needs a center seal/bearing kit this is qite common in the Amana / Maytag line.they are kinda hard to install you may need a service tech to do this for you the kit runs around 80.00 dollars and has instructions. if you need more help you can email me at [email protected]
SOURCE: eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
SOURCE: water leaking from bottom. what's up?
http://www.saecoparts.com/SaecoItaliaEspresso.html Check the diagram. Could be one of the internal plastic hoses. One of these caused the leak on mine.
SOURCE: Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
