FitBit Flex General Setup and Charging Tutorial
Please follow this steps
and fix it
Blessing
[email protected]
cell+whatsApp: +50588611441
SOURCE: Powers off by itself.
Has anyone gotten a resolution for this the only answer I saw was the SSB Board. Is there a cheap place to get parts. Philips model 50P8341 goes off by itself also wont come back on if you unplug it for a while it will come back on.
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
SOURCE: GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
SOURCE: the load starts out with
not sure but sounds like a mother board is playing up, try turning it off at the wall over night just to see if it will reset itself.
if not you will need to keep asking.
