[C550 (C780)] RADF I/F error (1) Check if the harness connecting the RADF board and SLG board is disconnected or open circuited. (2) Check if the conductor pattern on the RADF board is short circuited or open circuited. (3) Check if the conductor pattern on the SLG board is short circuited or open circuited. (4) Replace the RADF board. (5) Replace the SLG board.
Hi Jawad, I hope you came right if not you can maybe ask the guys over at Thoshibatech?
Toshiba Copiers South Africa 1 Toshiba Printers For Sale
SOURCE: service code c37 appeared on my toshiba photocopier
C37 indicates Abnormal transfer belt cam motor.
U need to perform below checking:
(1) Check if the connector of the transfer belt cam motor is not disconnected.
(2) Check if the transfer belt contact/release switch is working properly.
(3) Replace the transfer belt cam motor.
(4) Replace the LGC board.
