SOURCE: Wii connection issues.
You can check if the problem is with the internet connection going to the Wii or just the wireless connection.
When you loose connection, check the Wii's ip address. If it does not have an ip address(or ip is 169.xx.xx.xx) that means that the Wii is disconnecting from the wireless network. You can then try other wireless channels on your router.
If the Wii is still getting an ip of 192.168.x.x, that means that the problem is the internet from the router. You might need to forward ports on the router for your Wii.
SOURCE: Wii disk error
If the console try to read the disk, but you only get whirring and clicking noise, ending up with a no disk, and if this happens with all disks then it is a lens problem.
Try first cleaning the Wii lens with a cleaner disk, that is the easiest thing to do.
If that does not work, the Wii must be opened to access the lens pickup directly, and clean the lens with Q-tips and isopropyl alcohol, or replace the lens pickup.
If the cleaner disk does not fix it, better to contact Nintendo calling the number listed on the user manual to see if they can cover the repair, or replace the Wii, before disassembling the console.
SOURCE: wii wont read discs
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
160
SOURCE: error code 51031
Error Code: 51031 - I had same problem. Worked one day, not the next. I went into Wii Settings/ Internet/ Connection Settings/ Conection 1,2 or 3/ Clear Settings. Then click 'Search for access point'. Click on your your home internet (Sky, Virgin, O2 or whatever), input WEP (written on base of router) or private password if you changed the WEP when you first got broadband installed in your house and it should connect.
Did for me.
SOURCE: getting error code 8071053d tried
The error code indicates that the PS3 is unable to contact the Playstation Network Servers. This may be caused by the PSN (Playstation Network) being under excessive load (often a result of new, significant DLC being released) or a problem with your router or ISP (Internet Service Provider).
If you both of these connections prove successful, but you are still not able to sign in to the PSN, try:
Error Occurred. Press the Eject button and remove the disc.
Turn the power off and follow the instructions in the console manual.
BETTER U Click here to download repair guide
