Heating & Cooling Logo
Robert White Posted on Jan 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
American standard 80 only lights on second cycle, any known reason?
Jose Eliwer
Level 2:
Habit-Forming:
New Friend:
  • Expert 24 Answers
  • Posted on May 23, 2019
Jose Eliwer
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
24
Questions
0
Helped
36491
Points
131
artie g
Level 3:
  • Master 873 Answers
  • Posted on Feb 18, 2018
artie g
Master
Level 3:
Answers
873
Questions
0
Helped
245748
Points
2752
Check pressure switch
5 Related Answers
Anonymous
  • 11896 Answers
  • Posted on Oct 28, 2009
SOURCE: I have an American Standard
EIther the valve is faulty or the ingiter is corroded or faulty. The inside of the ingniter has a shaft with a probe that keeps heated so it can ignite. It can be corroded.
Anonymous
  • 43501 Answers
  • Posted on Feb 02, 2011
SOURCE: American standard 2 stage freedom
Check on the inside of the bottom cover to see what the two blinks means
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Anonymous
  • 247 Answers
  • Posted on Feb 04, 2011
SOURCE: No heat on the American
check the heating element if has a resistance or continuity using ommeter if busted replace a new one
Robert
  • 1036 Answers
  • Posted on Mar 02, 2011
SOURCE: How doI replace the motherboard
Hello, to replace the intergrated control board on your furnace you need to turn off main power to your furnace, then label the wires so you will know where they go on the new board. Then just take the old board to a hvac supply store and they will give you a replacement and just connect the wires to it and turn on Furnace.
Anonymous
  • 528 Answers
  • Posted on Mar 06, 2011
SOURCE: I need to replace an American Standard elongated
Places like these are your only hope.
http://www.toiletseatsource.com/
http://www.bathroomfurnituredirect.com/Toilet-Seats-C163494.html?refid=MS10334.replacement+toilet+seats
http://www.churchseats.com/
I have error code 114 on my American standard a/c. What does that mean?
114 is a communication error in the air handler. It can be the afc board, the blower motor or both. Cycle power to the AHU by the breaker. Leave off for about 10 seconds. If error comes back you will likely, at least need an afc board.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
How long does it take to fill an American Standard 3260-210
It holds 80 gallons. How big is your inlet pipe? How much water pressure? How many gallons per minute? Then you will have your answer.
Is the American Standard G50T 2-3-6 a good water heater? I have trying to find stuff about them on Google but I keep getting results for american water heaters not american Standard and the reviews are not...
Generally, they are a your normal low end hot water heater. I have seen American Standard units last up to 20 years (like mine) with not problems, and I have seen them not last three years before the tank ruptured.
We have more calls on the Rheem and Brandford Whites than American Standards as far an minor problems.
Pros: Cheap; reasonably reliable; parts readily available.
Cons: Not energy efficient; tank quality - flexible.
When mine goes would I replace it with another American Standard? No, I would install the Bosch tankless water heater.
I changed the furnace filter on my american Standard Freedom 80 filter and now my burner won't light.
does anything happen, i door that you removed might have a kill switch on it so if the door comes off or is not installed right the furnace wont light, let me know and maybe i can help. wally
5helpful
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Top American Standard Heating & Cooling Experts
Steve Sweetleaf
Steve Sweetleaf
Paul Carew
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
