SOURCE: Need Free Kenmore Automatic Bread Maker Model
I think this is as close as you going to get online without someone scanning their maual and sending it to you: http://www.managemyhome.com/mmh/owner_manuals/search/product.Breadmaker?query=Kenmore
SOURCE: Ice maker dispenser is not
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
SOURCE: Kenmore Model:106.56612500 side by side
cheapest and up,, check for a frozen water line, defrost the entire unit, any of the components can be iced up, once defrosted,, if you still have a problem, then check the inlet valve ,
SOURCE: I need a users manual
Retrevo has the manual here: http://www.retrevo.com/support/Sunbeam-4744-manual/id/952dj187/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
SOURCE: Have a toastmaster corner bakery bread and dessert
Have you looked under the bottom panel (remove the screws) to see if your drive belt has broken?
