SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
SOURCE: can walk on treadmill but soon as i start to run i...
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current limiting curcuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
SOURCE: Weslo treadmill stopped working during walk--like
Check the overload reset breaker on the front of the frame.
Eric
SOURCE: Treadmill INCLINE DOES NOT WORK?!?
Is it new? If so you need to call the manufacturer. If it is not, call Treadmill Doctor at 800-750-4766 and have you make, model and serial number of the treadmill ready so that they can diagnose it.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
