SOURCE: engine hesitates under 2000rpm in 1st and 2nd
It may be your map or maf sensor the connection to it to the manifold could be defective, have you noticed poor fuel mileage? if so then check it, also does it idle rought on start up or does it rev high when first started up? If it does you need to chek for vachum leak you can use a can of carburater cleaner to spray around hoses and see if it smooths out if it does at the area you spray it on that is your problem.
SOURCE: i have a chevy silverado i replaced the fuel pump
it sounds like a converter is plugging up,if it runs good when you are just feathering the throttle,then the more gas you give it the slower it goes,that would point to converter,since you didn't say the truck didn't shut off on you when you kicked it down,i wouldn't think it would be fuel,but you can check the fuel pressure at the reed valve on the fuel rail,you need to see at least 55psi of fuel pressure for the truck to run.
SOURCE: low end slip in 1st and 2nd with auto trans in 2000 Ranger pickup
check your kick down cable adjustment and fluid level
SOURCE: Hello I rebuilt my automatic transmission
Hello;
Two questions first. please.
Did you chk the converter sprag?
Is the converter and front pump properly engaged? Thanks, Ned
SOURCE: Renault megane 2006 1.6 sports
proberly not related. put wd40 in all locks and check battery.
